- Joined
- Jul 14, 2007
- Messages
- 1,825
- Reaction score
- 53
- Points
- 48
- Location
- adelaide australia
Photos of mod, god what damage you can do with a drill.
Ok your PhatDoggy on SBN.
I'm so sorryBTW, my bike is silver!
Aussiejules, have you got the 07 model or 06 model?The basic information the efi system needs is airflow to throttle position to adjust fuel. If the throttle is wide open and not much airflow the system detects(assumes) full load as if going up hill and adjusts moderately. If it senses wide open throttle and lots of air it knows(assumes depending on map) going flat out on freeway and gives as much fuel as possible because it knows it wont flood it. This atmosphere senser is also as a map senser (manifold absolute pressure) senser, other styles are the hot wire, the flap air flow meter, the flap airflow meter with a bap senser (barometeric absolute senser). All of these things have one job how much air is coming into the engine. The o2 sensor does help immensly in a/f ratios but the main reason for o2 sensers is emission control. there are still cars being sold without o2 sensers today. A pc would definately be a advantage to be able to better tune the bike to mods but the bike will sense and do a certain amount of changes itself to its capabilities.
is it safe to say then that with the 07 air flow metering that a non stock air filter and/or exhaust would be 'adjusted' for by ecu?
Wooo!!!!
Time for Dyno runs.
If on the 07 back to back dynos show more torque that would be cool. I generally leave stuff alone, unless I am putting on better parts, that will also let me remove and replace the stock when it is time to sell.
If there is a big jump with the box mod, someone will thermoform a new high flow lid. Show that it ads power, and make a bunch of money.
