ebster1085
Wow..just read this entire thread and can honestly say that the verdict is still out on this mod.
Personally, from my experience with tuning cars in the past (albeit bikes are usually run off simpler systems) here are my conclusions:
1. This mod WILL result in a freer flowing intake, and therefore SHOULD result in more power. Naturally more air and the same amount of fuel will result in a leaner fuel mixture, and therefore more power..that much is simple. The FZ's (07 and up) O2 sensor should be able to notice this and adjust slightly. That being said, the adjustments that can be achieved with the OEM narrowband O2 will likely have limits and not be all that accurate or precise.
2. Opening up the airbox will almost certainly increase engine noise and will likely produce a more throaty sound. Ever open up the clips on a stock cars airbox and go for a ride? With the box open, it immediately sounds throatier. Same applies here.
3. Should you do it? I went into this thread expecting that I would go home this weekend and modify the airbox. After reading it, I have decided againts it.
My bike is already loud enough and sounds great with the 2Bros slip on system, so noise is not an issue for me. As far as potential power gained, I dont think the relatively small amout of power I could gain is worth the risk of running TOO lean. Although I doubt this would happen, there have been no real tests done on the FZ as far as I can tell so its not worth the risk.
For a bike that I use as a daily commutter and a weekend warrior, I would say the potential gains are outweighed by the potential costs. I also ride in the rain often and dont like the idea that water could be more easily introduced into the intake system with the snorkel removed. Noone else seemed to mention this before.
K, I'm done
K, I'm done
