If that is what you read into it, then I guess so.
I'm stating that given a hole sized "X" and one sized "Y" with "Y" being larger, you'll get more flow through "Y". At the bottom of each hole is another hole, "Z". Z is a fixed diameter and will not change. Z will accept the volume of air that it's own diameter can possibly allow it to consume. If it is drawing from "X", it will have a challenge meeting full possible volume. If it is drawing from "Y", it has less trouble meeting that volume. If you remove all restrictions, Z will take whatever it can possibly consume and no more. Taking this into account, if we measured "Z" (four openings, one for each throttle body) and compare that measurement with "X" (the stock airbox cover opening) we discover that there is significant restriction. This isn't just on the FZ6 but on most production vehicles today. This is how aftermarket air intake companies like K&N make their money.
Within this system are sensors that read the volume of air along with the output of exhaust. The FZ6 is equipped with 4 sensors along the way. In the airbox, there is an air temperature sensor. In the intake assembly, there are the vacuum and pressure (fuel) sensors. In the exhaust before the Cat, there is the O2 sensor. (
WikiAnswers - What is the purpose of an oxygen sensor) The O2 sensor detects when the engine is running rich or lean and adjusts the fuel mixture accordingly. It does not matter what the intake is accepting for air volume, the computer will learn, computate, adapt and adjust based solely on the level of oxygen or lack thereof. If it finds there is more oxygen, then it will increase the fuel to create its "sweet spot" on its own.
A PCIII goes far beyond this smart bike by allowing you to manually map the entire RPM range to obtain the performance you want. It doesn't learn, it doesn't adapt and it doesn't adjust any more than what the owner tells it to do. People who use a PCIII and do not understand tuning and dyno testing will do one of two things. They will run very rich and pollute the air or they will run very lean and ruin their engine. This is why it's best to either know what you're doing when you buy one or let a pro tune the map for you. My point in this is the O2 sensor and stock computer does not negate the need for a PCIII. A PCIII is an owners personal choice to remove the capability of the bike's ability to adapt and force it to use the map provided regardless of intake, fuel and exhaust.
If I am wrong here, someone please point it out and show me where to find the correct answer. :thumbup:
