Guitar Man
Keep moving!!!!
I hope we are all a little educated on this topic and not just shooting off at the mouth. I think we can all agree that the air has to travel thru an airbox, filter, throttle body, intake manifold, and past the valves to get to the cylinders, in that order.
Without looking at the bike... I am guessing the Intake Air Pressure sensor is going to be after the throttle body, so changing the air pressure before the throttle body will have little to no affect on the ECU.
Gutting the air box will only ease the travel of air to the filter. I'm guessing this will make the bike negligably more responsive. Gutting it will create less negative pressure in the airbox, if there is negative pressure in the airbox to begin with. As a matter of fact, I am of the belief the air box could be removed all together, because your filter would cause more restriction to air flow than the box. Going with a less restrictive filter will have little change in the intake pressure, but again will make the bike negligably more responsive. Remember, this is a fuelly that pushes fuel in, not a carborated engine that sucks fuel in.
Unless you change something infront of, or behind the IAP, ie: the throttle body or porting the valves, you will not change the intake manifold pressure drasticly enough, to the point that the ECU can't handle it.
Just my $0.02... if the IAP is pre throttle body, my therory is shot to hell.
This is the way I think about it also. I am thinking of experimenting with running it without the airbox cover just to see what it will do. I figure the worst that could happen is fouling the plugs. I've read a lot about this and I am really curious now to see what will happen.
I bought a 99 V-Max about 3 months ago. It has an access cover on the airbox that is removed to allow easier air flow. The remainder of the lid is there just to hold the air filter in place. That thing screams in the entire range and sounds awesome. It even has louvers in the faux fuel tank cover that is just above the airbox. This is a common mod that has been done for years (since 85) and no one has seemed to have any problems. I have not found any negative feedback on any V-Max forums. And it's a fuel injected bike so it's adjusting the fuel air mixture ratio. Maybe the same thing can be done to the FZ's.
