Awesome. My goal is to also do this this summer.
makanouchi, do you think E55 projectors would fit in the FZ6 headlights? According to HID Planet, they are only about 13mm longer and 5mm longer from lens to mounting point
Hella 2nd Gen Bi-Xenon (aka E55):
Diameter = 79.80mm
Height = 96.95mm
Width = 106.15mm
Length = 163.35mm
Length(seat of the lens to possible mounting holes) = 58.80mm
Length(possible mounting holes to end of bulb) = 83.90mm
Width(between top mounting holes) = 77.25mm
Width(between bottom mounting holes) = 93.25mm
Height(between mounting holes) = 58.90mm
Infinity FX35/45 Bi-Xenon (aka FX):
Diameter = 69.20mm
Height = 105.10mm
Width = 111.80mm
Length = 150.70mm
Length(seat of the lens to mounting holes) = 54.60mm
Length(mounting holes to end of bulb) = 72.10mm
Mounting hole distances are not measured beacuse most people
would make their own and cut-off stock brackets.
http://www.hidplanet.com/forums/viewtopic.php?t=4394&sid=54bf610fc75a826205a965c6add56c65
light em up and take a picture.. they look great!!!
Nice job Mach! How did you make the plastic panels that mount the projectors to the stock adjuster screws? When I did my R6 projectors, this was the hardest and most time consuming part of the job. I also made mine out of sheet metal and had less room to work with since they are double projectors on each side.
The plastic panels came off the old reflector. I also though I had to fab them as well and was not looking forward to it but as it turns out, they were already there. I'll take some more detailed pictures when I get a chance.
