fazer.rider
Super Member
i didnt quite understand what haynes manual meant. it said "drill it", i worry i might mess up. since you can't get leverage to those security bolts. how the heck did the factory put them on to begin with? thanks.
I've done dozens of these and the best and easiest way is to use a dremel with a large cut-off wheel to cut a slot in the head of the bolt- so it looks like a regular slotted screw. Then use a hand held impact (the kind you hit with a hammer) to break the bolt loose. After that you can use a large flat blade screwdriver to thread it out. If you don't mess up the head of the bolt too bad, you can reuse it when you reinstall the new ingnition switch- or just get some new allen heads.
