madmanmaigret
Mad like crazy not angry
As some of you know my bike is currently under transformation from faired to naked (w/custom head light) :rockon:
I am at the step of having some brackets made up for a headlight I picked out (ebay listing has ended so I have no picture of it) :spank:
I like the headlight I picked out but I have now seen the Ducati streetfighter headlight :drool: and have come to a crossroads.
So my questions are these:
1.Rake on a FZ6 is 25.0 degrees and the Duc is 25.6 degrees so mounted in a similar fashion I shouldn't have to do to much adjusting to get the light in the correct spot....right?
2.Both bikes use 42mm forks. But the Duc's are inverted.....so the inside diameter of the triple won't be the same.....right? As in our I.D. is ~43mm and the Duc's will be bigger...correct? So I wont be able to use the Duc's mounting system and still have to go with a custom bracket for their light. ( I think this is inevitable any way as I would have to mount our gauge cluster...)
Ahh, just imagine a naked FZ with that sexy headlight, belly pan, seat cowl, in a burnt orange metallic :drool: :drool:
Well I will soon have some pics of my progress and hopefully (if all goes well) I will have her painted and put together in the next couple of months! ( if I ever make up my mind....)
TIA :rockon:
TIA :rockon:
