The manual doesn't want # 1 messed with as its the baseline for the Target Air Fuel Ratio (AFR).
If moved, you can use a vacuum gauge to get it back to a **near** ideal setting.
By changing the baseline #1 value you can adjust all cylinders to swing the AFR value (Rich or Lean) at idle. The happy spot will be when both the RPM and the manifold vacuum are meet the OEM settings. Hint: Those adjusters are setting how much air each cylinder gets. The fuel is basically a fixed value based upon engine temp and RPM.
Get all ports sync'd (+/-4mmHg of each other) and take note of RPM and manifold vacuum by inserting at "T" gauge at the
vacuum sensor (see pic).
- Turn all adjusters in an 1/8 to 1/4 observing the RPM and Vacuum.
- If both increase your getting closer to ideal. Repeat until rpm/vacuum declines.
- If both DECREASE, GO BACK. Open ALL 1/8 to 1/4. If both RPM and Vacuum increase your getting closer to ideal. Repeat until vacuum declines.
- In short, find the balance that achieves smooth high idle (NOT BY MOVING THE THUMB SCREW) and higher vacuum readings. For smooth year round performance, run towards the richer side = lower vacuum ###.
Too rich = lower idle speed, stinky exhaust, but better throttle response (to a point) and less likely to die from decelerating.
IDEAL = Higher vacuum but NOT the highest, Steady RPM. In short - From the HIGHEST Vacuum values, screw them in to richen them 1/4 to 3/8 of a turn.
Too lean = higher idle speed, but may stumble or induce slower throttle response when too far. Dies when coming down from RPM.
ALL Adjusters Turned IN = lower AFR = richer
ALL Adjusters Turned OUT = higher AFR = leaner
Connect a vacuum gauge using a "T" to the sensor shown here in the bottom right w/3 wires coming from it.
This assumes the CO (C01/C02) adjustments are the OEM values set from the factory and a fuel controller is not adding/removing fuel at idle.
EDIT 2015-04-14: Our FSM Does NOT state this but: Idle for
FZ6R is supposed to be set at 4.5 to 5.5%Co which equates to an
AFR of 12.83 to 12.43:1.
NOTES: Although 14.7:1 AFR is ideal for emission purposes, its too lean to run at reliably throughout all riding conditions - hot/cold, high altitude/low altitude, different fuel blends etc, thus running on the richer side helps the bike run reliably. That said;
FZ6R idle at vacuum is even higher than ours running at @32kPa (9.37inHg, 238mmHg) {4.5 - 5.5%Co}. Point; I'd guess our ideal AFR at idle is ~5.6%Co or 12.4:1 AFR.
FZ6 Idling condition S1/S2 models...
Engine idling speed: 1250–1350 r/min
Intake vacuum: 29.0 kPa (8.6 inHg) (218 mmHg)
Water temperature: 95.0–105.0 °C (203.00–221.00 °F)
Oil temperature: 75.0–85.0 °C (167.00–185.00 °F)
Throttle cable free play: 3.0–5.0 mm (0.12–0.20 in)
