How To The "Perfect Replacement" DIY Guide for 2015+ R1 shock installation on FZ6 S2 with height correction!
Kuttula
Farmington, CT 06032, USA
The 2015+ R1 shock can be easily modified with basic tools to fit with both correct spring rate and height on the FZ6. It is a massive improvement over stock without needing any internal modifications.
TLDR: Grind down the top of the R1 shock to fit, use the stock FZ6 spring on it, and Tap and Trim the lower R1 height adjuster eye to shorten it.
  1. Spring Removal: Without owning any special tools this was the hardest part of the whole job. To remove the springs, first I compressed the shock as much as possible while it was on the bike using the weight of myself plus the bike plus a ratchet strap around the swingarm. Then, while compressed, I loaded the spring up with zip ties to hold it compressed. Then take the shock off the bike, and slide the lower retainer off. If there is still too much spring pressure, large flathead screwdrivers can be used to leverage the spring so the retainer can be pried out. This needs to be done for both shocks.
  2. Spring Swap: The stock FZ6 spring is much longer than the R1 spring. However, it WILL fit with the preload adjuster maxed out, and using the stock FZ6 lower spring retainer. To get the preload maxed up all the way, remove the second locking preload ring. With the pressure it's under I doubt it will move on it's own, but if it ever does, I will just load it up with lock tight.
  3. Shock Top Grinding: It's not rocket science. Use an angle grinder, or whatever. See before and after photos. Wrap the shock in a rag to keep it clean from the shavings.
  4. Modification of the lower height adjuster eye: The R1 shock has a height adjuster on the bottom. There are 3 steps to make it go lower: Chop the blank tip of the bolt off, Tap the threads in the shock all the way down, and chop a 1/4in off the bottom of the shock. The bolt size is M16 x 1.0. Amazon has Tap and Die Set for 15 bucks. https://a.co/d/bLNabkA Because we are just making the existing threads deeper, the process is fool proof. Just screw the tool into the hole as far as it will go, and then clean up the scrapings. For trimming the bolt and the bottom of the shock I used a hacksaw, and then cleaned it up with a hand file, an angle grinder would also work fine.
The Stock FZ6 shock length is 11 7/8in. The Stock 2015+ R1 shock length (in lowest setting) is 12 3/8in. With modification the R1 shock is now 11 15/16in. This was just where I wanted mine. It could be made even shorter if desired.
I started with the Rebound dampening (lower screw) increased (turned inward) by 3 clicks. I haven't dialed it in yet, but this felt fine on the test ride.
A second OEM lower shock mounting bolt and nut will be required to use on the top shock mount as it uses a smaller hole.
I added Two washers to add some width for the top shock mount.
Map gas was needed to get the lower spacer removed. Mine was stuck solid, but easily released with some heat.
I have Race Tech gold valves and springs on the front, and I run the front much lower than stock for quick turn in.
The result of the R1 shock on the rear was Night and Day improvements for comfort and control. Total stability on bumpy corners at 130+mph.
