outasight20
Oh well, I spose I can get used to it. The handling is certainly better with the new bars.
Looks great! Couldn't you just put risers to prevent from having to rotate the bars for clearance?
Happy to help, but, does the picture above showing FZ6 and FZ1 bar side by side not answer your question? If not, can you please elaborate? The bars are same diameter -- e.g., the bar ends fit both bars.
Thanks,
Dennis
Today I received my FZ1 handlebar all across the ocean
Part number: 2D1-26111-01, hope its the right one
got it from Boats.net - New and Used Boats for Sale, Outboard Boat Motors, and Discount Outboard Boat Parts
I ordered it from the States,because european model 07-09 bars do not have the threaded inserts for bar ends/weights.
I'll do installation tomorrow morning,will let you know how it went tomorrow afternon when you americans wake up at about 5pm central european
Here's a pic:
Is it just me, or are those bent? I think if its laying flat on the ground like that the entire bar should be flat and touching the ground.
did you forget about the little pin(that needs to be removed)on the underside of the handlebar.
that's what it's sitting on :thumbup:
it's straight if I lay it on the backside
This Mod is just awesome !!
Here are some pics of my installation:
So, this mod allows me to keep my thread bar end inserts, correct? I have the heavy HVMP ones...
Thanks for the pics, which windscreen are you using?
