water pump seal
delfox
Manchester
Hi i recentley changed my coolant and after a ride i noticed a little bit of coolant drip from underneath the water pump. its never done it before. only thing i touched on the water pump was the drain screw.. if that seal goes inside the water pump i know it drips from the weep hole but my question is... will the water pump still work and i loose a bit of coolant.. or will it stop the water pump from working
