Maximokmo
Hi all,
My first post so Hello everyone, I am from London UK and have a FZ6 600 2006.
I bought it recently with 13000 miles on clock, great condition, previous owner kept it indoors and looked after it. It had been sitting for about 4 months before I bought it. It was riding nicely until one day when I left the tank raised to charge the battery, it developed an issue.
Now, the bike still starts but is a bit reluctant to. It will idle fine but if you open the throttle quickly, it bogs badly and loses power. This can cause stalling especially if uphill. However, if you very slowly raise the revs, it can reach high rpms. See video here: https://streamable.com/lo7lmd
The fuel was syphoned out and replaced with fresh high octane fuel, this hasn't helped. I changed spark plugs, checked TPS and CPS, all fine.
The fuel pump primes when starting but it does seem as if the engine isn't receiving enough fuel under heavy throttle action.
Today I drained the tank fully and removed the fuel pump (see photos of fuel pump filter and the last bit of fuel that came out tank which has a little water and gunk in it).
I don't have much experience with fuel pumps but this feels like it is the issue - it looks rusty and dirty to me. Is this normal levels of rust and gunk or is this excessive?
How can I clean the fuel pump properly? I have read that the filter is difficult to replace alone. Can I soak the whole thing? I have left the tank to dry out properly, should I clean that too? I have bought a bottle of Sea Foam fuel system cleaner, is that worth a shot?
Thank you for any advice in advance!
