Turbo time. Seriously.
killernoodle
Making stuff
Charlotte NC
I've built a lot of turbo cars, I know my way around turbo sizing better than most. Right now there is a turbo LS1 swapped 240sx and a rear mount turbo CTS-V sitting in my stable :)
FZ09Bandit
�� Paramedic ��
Arkansas
Nice! I got a 97 eclipse 4g63T I gotta build if I can find the motivation to get up off my ass.
An added pain point here aside from the oversize is the mass of the shaft and impellers - simply too heavy to spool and track or match what this engine is capable of.
And as stated, a turbo that big needs lots of oil. Hopefully this doesn't cost you the bottom end of the bike as its essentially a big oil leak.
Love to see it work tho!
killernoodle
Making stuff
Charlotte NC
ITT: people who think they know stuff about turbos lol
Seriously though, this turbo is really small. Plenty small for a 600. Being small it should spool up fine. And turbos use way less oil than you make it out to be.
Anyway, here is the turbo mounted up. I had to modify the water neck to get more clearance for the wastegate actuator rod.
04fizzer
Fairport, NY
It's a shame you couldn't do the rear mounted turbo like has been done with the new corvettes. It'd be a cleaner install, but there's no room, sadly.
I can't wait to see this thing running. Extended swingarm?
siebsey
Cincinnati
I think I'm going to
killernoodle
Making stuff
Charlotte NC
I did a rear mou t s475 on my CTS-V,but that wasn't the best option here honestly.
I'm probably going to switch to an r6 or r1 swingarm whenever the turbo is done. Not extended of course (ew).
The forks and tire have plenty of clearance.
04fizzer
Fairport, NY
No doubt, space is definitely limited on a bike.
If it fits, it ships. Sometimes you just have to bend the box a little.
ChanceCoats123
Chicago Suburbs
Well I am definitely following this build! Any plans for a BOV? It would be pretty sweet to hear this thing blow off 8 pounds of boost! It would turn my head more than a parade of models! :eek:
killernoodle
Making stuff
Charlotte NC
I've got a greddy type rs sitting around that I'm going to use. It should be loud enough with this big plenum. I might find something smaller though.
FZ09Bandit
�� Paramedic ��
Arkansas
People be like... DAT BIKE BE SNEEZING
If only I had the know how and equipment to force induct the 9. Has plenty of bottom end to spool a decent snail. Albeit a supercharger would be nasty!
Didn't we have a member s/c a fz6?
Water Bear
Fireball
Georgia
Looking awesome!
I guess I'll join the 'think they know' crowd, but in the other direction. I'm no engineer, but your explanation for how the turbo should work sounds believable, right? It sounded like you were saying that at X motorcycle rpm you estimate you will have the same flux of air (the same volume per minute) hitting the turbo as when it's mounted to the car, so you figure that's when it spools up (assuming exhaust speed is roughly independent of rpm). Sounds legit to me.
If a guy say he knows and gives a reasonable explanation, make pop corn and watch!
motel6
portland
Holy crap.
I know nothing about the technical details of this, but I know what a Turbo is...looks awesome!!!
SweaterDude
Broke-zillionaire
as far as room goes, i wouldnt be worried about the forks and wheel so much as the radiator. but im assuming you looked into that.
and for the swing i would try to run the R1 swing to get that wider 190 section under the bike.
have you thought about butterfly dumps for the exhaust? then when you run in less than ideal conditions the exhaust can choke up the flow and create a "rain mode" of sorts. then flip the dumps and have one BAMF when you desire.
