- Joined
- Jul 30, 2007
- Messages
- 5,423
- Reaction score
- 98
- Points
- 48
- Location
- Adelaide,South Australia
Yours is an '08 mate,def.not TPS .
Hello everybody.
This spring I bought my first bike FZ6 2006 it was on 6000+ km and since then I've clocked 5000 more km without problem.
Last night as I was cruising on some county roads when I felt a sudden drop in power for a half a second then the nightmare began. Almost every time I tried do accelerate hard between 5-9k rpm the engine gets killed (like there was now gasoline but the tank was almost full). When I turn the kill switch off then on and release the clutch i starts like nothing happened. I tried it in neutral the same thing the engine gets killed around 5k rpm and immediately after that at 6k rpm. Then I rock the bike hard (compressing the suspension back and forward) and tried again it rev up to the 14k rpm easily.
Last night I made the diagnostic thing Do1 and it showed 16-100 with no skips but the engine was cold![]()
I will try to stall it and immediately run the d01 when its hot.
What else except the TPS can it be ? I suspect that crappy fuel may block the fuel pump filter!?:don'tknow:
Hello skodilak,
Apart from the TPS, the reason might be as trivial as a clogged air filter. I had both problems (the clogged air filter and the faulty TPS) occur approximately at the same time: when the bike was at 10 - 11 000 km (nasty coincidence, isn't it?). After servicing the air filter, the bike went smoothly for a while and then the problems started again.
The issue was finally resolved after I had the TPS replaced. By the way, I had to take the bike to a non-yamaha repair shop. Shortly before that I found the following technical bulletin on the web. The info here is quite useful in case one has to replace the TPS on their own.
http://www.starchapter451.org/docs/tps_yzf-r1_fz6.pdf
Good luck![]()
I have an 04 thats on occasion will stall while coming to a stop. When engaging the clutch and releasing the throttle the bike will stall out while rolling to a stop, a really big pain in the ass while in trafficIs this TPS issue the cause of that?
Thanks!
mine had the tps recall bout 4 weeks ago and is now sittin in a strangers backyard 25 miles away, i dunno what to do, starts fine revs fine with sidestand switch spliced and connected at harness end still no joy, soon as u engage gear it cuts engine any help appreciated.
