- Joined
- May 8, 2008
- Messages
- 15,007
- Reaction score
- 1,178
- Points
- 113
- Location
- San Diego, Ca.
It sounds like the standing voltage on the LiPo is going to be higher than the standard. If those batteries want a higher charging voltage there may be some incompatibility with our charging systems. I would like to see what your actual cranking voltage is looking like.
There is the possibility the optimal charging voltage for the LiPo is 15 plus volts and the standard bike is a few volts.
I've just done a little research and it seems there are warnings about proper charging of these type batteries and they specifically say you need a charger for that type battery. Does this negate our bike charging systems from having optimal compatibility?
So let's just try to look at cranking voltage. If there is below 8-9 volts there may be a problem and that might be the primary intermittent hard starting issue. Waiting to hear what Shorai says!
