mvthai
ok, got home late from work today and didn't have much time to work on the bike until after dinner. well, as Scott mentioned, when I pull the plug to the fuel pump, the 10a EFI fuel doesn't blow when I turn the ignition to on. but when I plug it back in, turn the key to on, fuse blows again.
I did some readings on the wires to the fuel pump and it seems to be working correctly. when I turn the key to on, I get a 12-13v reading, off = 0 and yes, its grounded.
can I assumed that the fuel pump went bad somehow, causing a short from inside the pump housing? is this my next move, to replace the fuel pump?
