[email protected]
hi can someone tell me if it possible to adjust the c1 & c2 on a 08 s2 and how to do it,just need some info:thumbup:
Instead of starting a new thread I'm going to try to jack this one. I'm wondering if someone has a link to the how to for the co adjustment for a US FZ6. I've searched google, sbn, and here to no avail. The link that I actually found is now broken and leads to no where. Any help is greatly appreciated.
This thread has a lot of info about it:
http://www.600riders.com/forum/fz6-mods/4809-dyno-tune-co-adjustment-leo-vince.html
Thanks for the link. I'm still wondering what he means when he says,
"Here's a picture that outlines where the new ground wire goes. I used a flattened db9 pin to fit into the plastic plug and connect to the jumper that I grounded on the brake reservoir mount bolt."
I can't decide if he means he inserted a pin into the open spot in the wire connector and then grounded the wire that ran to that open spot, or if he meant that he had a ground wire going to the pin inside the connector itself. Other than that I think I understand it.
he inserted a pin into the harness and then connected the wire from that pin to ground.
