lever arrived this afternoon, looks great, I wish my welds could look that nice. Can't wait to get it all installed and adjusted. Thanks killer!
If the clutch pull is 25-30% less stiff, the engagement zone is also 25-30% longer. I've been to the drag strip several times with the mod and the clutch is much easier to modulate to get exactly the amount of torque I want at any given time.
I guarantee you will stall less at lights, take off smoother, shift smoother, etc with this mod. I honestly don't understand why Yamaha didn't make their clutch like this at the factory. I've felt literbike clutches that didn't feel half as horrible as the stock FZ6 clutch.
As far as adjustment goes, when you take the lever off you can put the new lever a spline higher on the shaft to get your adjustment back to factory.
Basically, installing the new lever goes like this:
- Install the cable hanger bracket with the cable in the 2nd(new) position.
- Screw the handlebar clutch adjustment (clockwise) and the mid-cable adjustment all the way in.
- Pull the cable at the motor as far out as it will go to pull the lever at the handlebar all the way out (we need to remove all slack in the cable, just pull it taut)
- Install the new clutch slave lever onto the cable(but not onto the splined shaft.
- Put the clutch slave return spring in place.
- Rotate the clutch input splined shaft clockwise until it stops to take the slack out of it.
- Position the new clutch slave lever over the input splined shaft and rotate it as hard counter-clockwise as you can before you slide it on the input splined shaft (this is to take all of the slack out of the cable).
- When the lever is on the input splined shaft, put the clutch slave return spring on the clutch slave lever.
- Tap the clutch slave lever all the way down and reinstall the factory washer and circlip on the splined input shaft.
- Adjust the master lever at the handlebar until the desired engagement zone is reached.
Ha! Damn, I should have noticed!
Thanks. Paypal sent!
Looks like you are in line for a core, i just checked and the parts i ordered got to him today, as soon as i get them back i will get that core off asap so you wont have to wait to long.
Yep, I got them today. I might be able to get it off early tomorrow, but much more likely it will be Monday morning.
I'm still going to need 2 cores, one for myself (since I sent out my personal lever off my bike to get it to someone quickly) and another for the next guy in line.
Killer, I'd like to do the send you $70 and you refund when I send you my core (to not have any downtime). Do you have one modified that I can claim or are you not doing that anymore?
Sorry to hear that, I'm ordering some other parts now I'll just throw on these two and ship them to you. I'll paypal when I put them in the mail. Sounds like you could use my core when I swap it out?
Musky Mike said:Hey, I've following the tread somewhat...so this mod give a light clutch pull??
use the 20 that you would send back to me to buy a core for you. was only a few days wait till it shipped.
tomorrow or Monday its all good, ill get them on asap and get my core back as soon as i can.
Looks like it is going to be tomorrow. I was going to take them to work this morning and noticed a spot on the end of the lever that looks like the powder coat went on a little light. I'm going to redo the powder and make sure you get a flawless lever.
How much does it cost and what do I have to send in and how long would it take?
