Scott, I do not have the user manual, even checked under the seat but only found some tools. If you can send me the PDF that would be great.
I worked on the bike today and succesfully resolved the sticky throttle by loosening the cable a little.
I also flushed the coolant, put in new Prestone 50/50 and went for a quick ride to let the engine warm and I am now second guessing myself regarding the overheating. When I ride, temp. Is either at 2 or 3 bars. I stopped at a gas station to adjust the tire pressure and I let the bike run for 5-7 minutes after which it went to 4 bars and the fan kicked in. NORMAL, TURN IT OFF! THERE'S NO REASON FOR IT TO RUN
When I left, went back to 3 bars almost immediately. GREAT-NORMAL
Got home and as I was parking, fan was running.HOW LONG DID YOU RIDE TO GET HOME/ HOW FAST Turned the bike off, put contact back again and fan would engage right away with full bars(engine off). Are the bars maybe always to the top when the ignition is on and its not really overheating?
Thanks!!
PM me with an e-mail address to send the manuals to.
The FZ does not have alot of extra voltage, (IE, one LB headlight).
Leaving the engine running for no reason is hard on the charging system, now the fan IS KICKING ON (making it worse charging wise) AND your heating up your engine for no reason.
I don't have "bars", so the "norm" for that, IDK. Sitting in traffic, especially for awhile WILL obviously kick on the fan.
Sitting / running getting tires aired up, DON'T!
We don't know how far or fast you went after the initial fan kicking and you got home. You
may have simply not ridden far/fast enough to drop the temps.
IMO, ride to wherever your going,
turn off the bike.
**Do your riding /
PARKING -ENGINE OFF, as such and report back how it behaves.
If there IS an issue, it's likely NOT a thermostat (from your posts), but
could very well be the radiator cap not pressurizing.
Besides an auto parts store testing it,
once your bike is to temp, squeeze the large hose to the radiator. It SHOULD BE HARD.
If it's NOT, soft, you have a leak in the system not allowing it to pressurize (most likely the cap).
My S2, the fan VERY RARELY comes on. It kicks on about 210F but it's rare I ride in heavy traffic, (temps in Florida similar to yours, actually hotter now in summer.)
My normal operating temp is roughly 172 - 180 F
