The FAZR6 FE kit doesn't "join" to the Scorpion license plate bracket kit, as the FE kit has no provision to attach the Scorpion bottom bracket, which is designed to attach to the stock OEM rear fender. You have to use Scorpion's horizontal large "U" shaped bracket to attach the FE kit, which is not as strong as the OEM "U" bracket, so your plate and flashers will bounce quite a bit.
You do have some simple attachment alternatives, however:-
-attach the Scorpion bracket kit (top bracket/extension arm/lower bracket) and use plastic cable ties to secure the FE assembly to the Scorpion lower bracket
-as above, but instead of using plastic cable ties, drill a couple of holes in the top of the FE bracket and the Scorpion lower bracket and secure using self-tapping screws or small screws and nuts. That's what I did. The whole assembly is then quite solid. Much better. :thumbup:
I'll try and upload a couple of pictures today to illustrate the above.
