I put about 13,000 on those plugs. How many times did you change your air filter during that 20,000 and do you have any power mods? My bike is all stock in the power department. I was not under the impression that my plugs were \"having any issues\" I just thought I'd post this pics...I don't remmeber noticing a difference in performance after changing them out.
looks like you could use to lean the bike out a bit, those look a bit rich to me, but as said before they are very consistent which is good. you could try the CO settings if you don't have a PCIII.
If you'd been cruising on the highway, and had hit the killswitch, then pulled the clutch in, and coasted to the side of the road, and without ever starting the bike again, removed the plugs, then yes, those would be a little rich looking.
Because that's how you're supposed to pull plugs to read them.
But since what you probably did was to ride somewhere, come home, putt along your neighborhood streets to your house, pull into the driveway and then shut the bike off, you're not getting a fair plug reading. Idle and low speed is going to be rich, which is what your plugs indicate.
So they're fine.
I was thinking the same thing, just a little be fat. That said I've never pulled plugs in an FZ before.
I don't recall that the interval is for changing, 12K?
1 question is there any easier way to remove the plugs?
man i did it and was A PITA manual said remove lower radiator bolt and thats it
no room for nothing![]()
I think the 2007 modlels and up are much easier to replace, as the spacing from the radiator has opened up a bit more from the later models.
Well I finally changed out my plugs after 12,000km's (7456miles) on the odometer. Not looking too bad....
