CR9EK stock plugs
tuning-forks
lower Manitoba
So the stock plugs are boxed at .7mm from NGK. Yamaha spec is .6 to .7mm for the FZ6.
I have read that the dual ground plugs should never be gapped. If that is true, any significant mileage on the plug will probably put it out of spec. I would love to hear from a Yamaha service shop whether they gap them, or just replace if they have any wear on them (because they come pre-gapped at the max. allowable).
Before I read that they should never be gapped, I tried. I have several of the proper gapping tools for regular plugs and none would fit into the tight space on the CR9EK.
A couple questions, are most people using single ground plugs instead of the EK's ? Or if you are using the dual ground EK's, what are you using for a gapping tool?
Just put in Iridium's, don't check gap and go ride..
Should you want to check gaps in the multi strap plugs, use a "wire" feeler gauge.
Also, when the gap goes beyond spec's, their worn. Yes you can tighten the gap, but they
should be replaced..
I think you might be overthinking this. If the plug gap is in spec, then you are good to go. I get concerned if the tag is less than expected because it means the plug was dropped and likely damaged. If 3 plugs are at 0.7mm, and one is less and tighter than the spec…that plug gets replaced. Otherwise use them as they come out of the box.
So much conflicting information, sometimes from the same members. :D
The CR9EIX come pre-gapped at .8mm, I agree with @Motogiro 's caution about too large a gap in a wasted spark system.
CR9E are pre-gapped at .8mm as well. CR9EK are at least in range being pre-gapped at .7mm
If the '09 bikes are spec'd to use the plain E with a gap of .6 to .7, then I am pretty sure Yamaha expects them to be set to proper gap before install. I think that would be good to do with the EIX as well.
At least both the E and EIX can be gapped down to .6, which leaves some leeway for wear before going out of spec.
