Yamaha to ditch FZ6 for FZ8?
I was looking at the info about the Mt-03 from the link you gave,and I realized it has the engine from the Raptor 660cc 4-wheeler!! it has a mountain of tourqe for such a light bike.... heres the #'s from the link.... Yamaha MT-03 2008
Category: Naked Bike / Streetfighter
Specifications
Engine
Engine type: Liquid-cooled, 4-stroke, single cylinder, 4-valves, SOHC
Displacement: 660 cc
Bore x stroke: 100 x 84.0 mm
Compression ratio: 10.0:1
Maximum power: 35.3 kW (48 PS) @ 6,250 rpm
Maximum torque: 56.2 Nm (5.73 kg-m) @ 5,500 rpm
Lubrication system: Dry sump
Fuel System: Fuel injection
Clutch type: Wet, multiple disc
Ignition system: TCI
Starter system: Electric
Transmission system: Constant mesh, 5-speed
Final transmission: Chain
Chassis
Chassis: Steel tube truss diamond
Front suspension system: Telescopic forks
Front travel: 130 mm
Rear suspension system: Swingarm
Rear travel: 120 mm
Front brake: Dual discs, Ø 298 mm
Rear brake: Single disc, Ø 245 mm
Front tire: 120/70-17
Rear tire: 160/60-17
Dimensions
Length: 2,070 mm
Width: 860 mm
Height: 1,115 mm
Seat height: 805 mm
Wheel base: 1,420 mm
Minimum ground clearance: 200 mm
Dry weight: 174.5 kg
Fuel tank capacity: 15 L
Oil tank capacity: 3.4 L
even sounds like a 4-wheeler!! YouTube - Yamaha MT-03 in action!
that engine is actually the newer 700 raptor engine with a 2mm smaller bore. both of those engines were in the bikes before the quads
If they were going to intro the FZ8, shouldn't it be on the 2010 lineup online or is this another bike that only Europe gets for the first 1 - 2 years?
Glad the FZ1 is still there! :D
C'mon Yamaha, just build this one and be done with it:
This came up under Google images when searching "Yamaha fz8"
I'm not sure if it really is the fz8, but it does appear to have a bulkier, and naked front end. Maybe its just my imagination or the angle the picture is taken at, but regardless its a nice Yamaha.
Yeah i realized after i did a little more investigating and it as on a forum talking about fz6's...oh well, i would be embarrassed if i actually cared haha.
Too bad - I liked the 600cc. Plenty for the street, good on insurance (my company goes strictly by displacement).
I did recently pick up a bike powered by a Yamaha Raptor engine (the 660cc carbed one) - a bit of a different animal than the FZ!
I started with a Ninja 250, went to a FZ6, FZ8 would be a nice step up the ladder. Especially if it was a little brother to the R1's cross-plane shaft engine!
Anyone heard anything on the FZ8 release? I find it weird that it's a 2010 model and we're almost through Jan. 2010 and there's no word on anything for the FZ8.
