windshield mounting harware
nyctpt
NYC
I pulled my windshield off today to do some cleaning and discovered that it was being held on by one nylon screw, the other 4 were broken. Guess I'm lucky that it didn't come off will riding. I found a few nuts/washers/bolts that have it secure for now, but I would like to get the original hardware or an alternative that's just as good. Any ideas on sourcing the parts? Trip to the dealer?
Also I'm going to be ordering a new screen in the near future, Puig I think. Do they typically come with hardware?
Thanks,
Ryan
dschult2
wyoming,mi
I'm in the same boat as you are. Washed my bike today and noticed I was missing two screws. One for the windshield and one for instrument cluster. But I think I may just use the same screw as the instrument cluster as I believe it the same size but metal not plastic. I believe you have to reuse your hardware but the Puig may come with some sleeve adapters, not sure. For some reason I cannot post a website link but you should be able to find screw you need at Bikebandit.com. The part # for the windshield screw is 1265466 and the # for the metal cluster screw is 1264710.
beatle
Springfield, VA
I'm guessing you have an 04-06? The 07+ have 6 screws. At any rate, I think the screws are the same. You can pick up a set of screws on ebay for $6 or so.
They are metric thread and steel screws will fit HOWEVER, I would NOT use steel screws. Its a safety issue
There's rubber sleeves (in the fairing) and the plastic screws are DESIGNED to BREAK AWAY, (and the windshield) should you crash and go thru/over the windshield.
The screws are very easy to bust off (if heavy with the screwdriver).
As I re-call, you had to buy a package of 5 or 6(comes with the rubber inserts and screws). I still have two plastic screws left and 5 inserts.
Their the same for the FJR and the FZ, same purpose too..
I would strongly suggest you just order a package, they'll last a while.
SIX OEM screws for $1.47 TOTAL;
Parts 2 and 3 now;
2007 Yamaha FZ6 (FZS6W) Cowling 1 | Babbitts Online
I probably wouldn't bother with the rubber grommits, I'd just pick up some screws, black plastic...
nyctpt
NYC
Re: windshield mounting hardware
Just ordered from Babbitts, thanks for the info.
Ryan
bpchura
STL
I can say that the safety feature break away bolts are a real thing. When I hit a deer head on a few months ago, the whole front end was totally destroyed. Sure enough, the windshield was found on the road totally undamaged and the nylon screws in (what was left of) the front end. It was nice not to have to buy a new windscreen (in addition to an entire front end!) In an accident where you are going over the front, it would be nice to have it snap off as opposed to shatter and potentially be sharp.
RoadGator
Tampa
They are more expensive there than on Amazon. I just looked and HOLY CRAP! $18.77
Your NOT ordering 6 screws.. One part CONTAINS 6 screws, its $1.47 total.
I believe, as you check out, you can change shipping options as well.
RoadGator
Tampa
Oh ok, I was about to say. Yea Shipping was the killer. Just throw it in a envelope for .50 and call it done i say.
Sometimes, especially for that small an envelope, you can call and see if they'll cut down the shipping (depending on the company).
$10.00 is absolutely ridiculous
