ELIZABETH
Goofball Extraordinaire
. I weigh 170 and my girl weighs ~110 (I don't ask, lol). We also had about 20-25lbs of gear.
You are a smart man, Larry in PA!
Can you really feel a difference in the settings?
The manual shows the wrench being inserted at 9:00 (analog clock hand).
That would make the handlebars at 12:00, and the brake lights at 6:00
Given that, where is the position indicator located?
The indicator is located at 9:00 inside the little slot where you put the wrench; it's hard to see, but it's there. it visible at a precise angle. I've got 50 year old eyes, so If I can see it...
If you look from 9pm from the side where you insert the wrench, you can see the slots each with the numbers below them. Also at 9pm, if you look through the slots are two holes in the metal in the cylinder behind this one. These are the indicator marks, and as you turn the wrench, a new slot moves over these and clicks in place. Whatever number is below the slot is your setting.
Hope that helps.
I have it set for 30-35mm of rear sag
