brico
Since I replaced my stock exhaust with TB cans, similarly to other people, I have noticed that right side can is "working harder" getting way more hot than the left side one and I guess this is because of the shape of the pipes and right side one having much more straight exit so more hot exhaust gas running through it. I am sure this was the case with stock exhaust but because both cans were together the heat from the right side migrated through the assembly to the left one so the entire thing would be similar temperature. With divided cans, this is not the case.
So, do you guys alternate the cans every now and then to "burn them out equally" or just keep them as they are? It is pretty easy swapping the cans, but how often would you do that?:don'tknow:
