pyroclastic
Decided to Sync the throttle bodies on my '07 FZ6 this afternoon. Read the service manual and this forum to get some hints. I bought my FZ6 at the end of June '07 and have 5120 miles on it. I decided that it was time to do some routine maintenance. I have a Morgan Carbtune Pro and decided to put it to use.
Once I had the tank up (used a bungee cord to hold the tank up as another member suggested :rockon I took the cover off of the airbox and checked the air filter. There was more dirt on the cylinder 3 throttle body location (Cylinder 1 (left) to Cylinder 4 (right) as you are sitting on the bike). I figured that the excessive dirt was due to an mis adjusted throttle body. Thanks to Yamaha the throttle body sync process could not get any easier as they provide four rubber vacuum hoses with plugs in them to connect to your carb/throttle body syncing device. Simply pull out the vacuum plugs and put in a straight coupler and you are off (Autozone sells an assortment of vacuum couplers).
I was amazed that even after 5120 miles that my FZ6 hardly needed any tuning. Cylinder 1 seemed to be the most out of calibration as you use Cylinder number 2 to perform the throttle body sync. Once I had Cylinder 2 calibrated to roughly 22 cmHg, I then followed the service manual to calibrate the remaining cylinders.
After a ride I think that the bike ran smoother, but honestly I think that just readjusting the idle screw did just as much!.
