The count of 1 down 5 up is in relationship to neutral; green light on dash. Going from 1 to 2, or 2 to 1 will almost always result in a "klunk", that is neutral. If you are not going all the way down, past neutral, you are only using 2-6. Here's another way to figure out is you are in 6th, at 60 mph you should be a ~5,000 rpm with stock gearing. If you are at 5,500 at 60, poke her one more time.
And yes, the FZ will spank the Ninja in all regards.. The ninja motor is bulletproof but it is akin to an agriculteral water pump. With the right rider the FZ6 will run from 636s, 675s, and CBR600s. It is all about the rider.
