Outlaws Justice
- Joined
- Jan 31, 2009
- Messages
- 54
- Reaction score
- 1
- Points
- 0
- Location
- Watertown, New York
Riding in the Rain
I always find that many people have a fear of riding in the rain. What can you do if you are caught out in the rain while riding or are forced to ride thru rain for any one of many reasons? So what can you do?
You need practice. I find when teaching that rain is one of people biggest fears. One of the reasons I do not mind teaching the BRC or ERC in the rain. It really helps the students out so much more than learning in sunny weather. They learn right at the start that riding in the rain can be controlled. So find that parking lot, and get to work! (On a rainy day of course!) When you and start to practice in the lot there will be no traffic but it will still help you rebuild your confidence. Then work up to residential areas where you will have some traffic and so on.
So you say: "Yeah, sure, but the feeling I have is that wet surfaces don't give any warning. One moment you've got grip, the next it's gone. How then, can you practice ...?
You must realize that cars hydroplane much more easily than do bikes with good tires. The rounded profile and carefully designed tread patterns on bike tires really limit hydroplaning - you would be down in a second if they didn't. Car tires with lots of the right kind of tread will resist hydroplaning, but as the tread gets worn cars hydroplane pretty easily. And being on the verge of hydroplaning really feels like the car isn't planted. It's just going to take you some time. You can ask just about anyone that has crashed on a motorcycle. What ever caused them to go down, sharp right hand curve in a downhill, decreasing radius turns etc, will cause them to be uneasy for a while. Just hang in there, practice, and practice and you will be fine.
First and foremost you have to get past the fear, it takes over your brain and does not allow your mind to make decisions and take corrective action. No conditions give warning. I ride Dirt as well, it can be firm, loose, slippery etc. You have to ride the bike, look ahead, think of what you want to do and do it all without FEAR. If you are scared you are not doing the many things that riding the bike requires. The bike will hold traction much better than most of us can ride it!!!! Even in the rain!!!! You need to trust your tires!!! Try using your rear brake when it's wet to test how much traction you have available. And as others have said, a lot of it is mental. Just need to relax and be smooth on the throttle and brakes. Trust is a learned behavior. If you have some past experience with the available traction in the wet then your trust of your bike, tires will improve.
In the wet explore available traction with the rear wheel primarily, and only with the bike straight upright. You can do the rear brake test, or acceleration test (in a controlled environment). I was impressed once when I was able to loft the front wheel in the wet, not that I was trying... but it's just a testament to the grip of good tires these days. Of course I have spun up the rear as well in assessing traction in the wet, but this is all part of the learning experience... this is where you will build trust of how much traction is there. Good tire tread depth is much more important for those of us who ride in the rain!
Other than working with some trainers and doing some practice there is not much else I can actually tell you. When you are out on the road and it's raining, don't let the drivers behind you push you out of a comfortable range of speed. I'd rather be safe than appease the person behind me by speeding up, I hope this helps.
