Re: Abnormal wear of rear brake hanger. What have I done? Help!
I just saw that in one of the photos it had the pads in it. The pads don't look worn out. Is that correct? Or are they worn like wedges?
The point being, you need to know what caused this so it doesn't repeat itself. Do you know why this happened yet? Can you confirm wear makes (points of contact) to confirm or deny the bracket was properly engaged in that slide in the swing arm? Look close. There must be something to be seen once cleaned up.
Ha Ha, It has been raining for the last month, there is so much crap on the lanes.
It's dirty pretty much 99.9% of the time.
So an up date:
I have taken the disk of and used a piece of glass to see if the disc is true. There appears to be no warping. I do not have a micro meter or calipers so the glass was the best I could do.
The guide that the caliper runs down has no abnormal wear on it. The only thing of note is that there is about 3mm gap. The bracket doesn't sit flush with the swing arm.
Is that normal? The bolts that hold the the caliper are also true.
I recall that when I did the swing arm pivot bearings the swing arm was a total B@@ch to -re-align. Could I have twisted the swing arm? No hammers were used for the alignment just a lot of swearing and tears.
I have purchased a caliper bracket from Steve Allen and it should be here in about 10 days. I will clean up the back end and do a re-install and see whats what.
Thanks for all of the very useful input guys.
Nelly
