That video makes your guts churn. No gear and he slammed into a guard rail at speed.This guy did it wrong on his BMW S1000RR ....needed wayyyy more room to slide.....
YouTube - Scary wheelie crash‏
I bet this boy had a few fractures?
Nelly
here's another neat wheelie video, looks unintentional...
rider makes out ok, bike not so good
edit: watch the speedo on the bike with the cam....
douchebags are going 90 MPH through a residential neighborhood
with any luck the courts were able to see this and take the a-hole off the road for awhile
YouTube - Motorcycle Wheelie Crash Fail‏
I'd start by kicking your bike over in the driveway right now. That way it will be banged up when you start the wheelie process and won't hurt as much when you eventually go down.
One of many such 'f-up' bids I've seen. Glad he hit the pavement, I would NEVER ride like that in such an uncontrollable environment, completely ignoring the accidental and monumentally rubbish wheelie.If one of my mates did, I would assure them that they would never ride with me again.
would have loved to be the guy in the red truck pickup they passed
at 60MPH against a double line around a blind corner, then find that
asswipe lying on the road and his bike all smashed to shyt...I'd stop
and laugh my ass off at the DB
-A 15 tooth front sprocket will improve your power immensely. (I did the change and it helps a lot to lift that front end up)
-Switch the back suspension to factory settings (3)
-Release some air from your tires
In order to success a power-wheelie, you should drive at 1st gear accelerating hard to about 30-50 km/h, then immediately release the throttle entirely until you feel a significant deceleration and a slight pressure on the front suspension.
Now it's time to fully open your throttle again and enjoy your liftoff!
The feeling is kind of scary the first time. Be careful not to lift the bike to much and loose control.
Be prepared to drop the throttle again ,if needed, to get the bike down again. Have your right foot on the brake pedal just in case
In case you get the front wheel down not perfectly aligned, you might experience a wobble (that might result in tank slapping). In order to avoid this, try to accelerate while wobbling to stabilize the bike.
I am also experimenting with clutch wheelies. Did one yesterday but it scared the **** out of me. Felt like to much uncontrollable power to me...
