OSO2K Setback Plate Install
Hellgate
Moto Demi-God
AUSTX
Okay out of popular demand is the OSO2K Setback Plate Install. Before I get into this many thanks to Louis (OSO2K) for taking the time to make these. It is a HUGE amount of effort to have custom machining done. That and all the Doubting Thomas' are a huge PITA. Also thanks goes to Mattcosta7 and afpreppie04 for the great ideas on how to deal with the shift rod; I pirated from both parties! :cheer: (There are plenty of good wheels out there, why invent a new one???)
So to begin with here are the plates and the look of the stock rearset placement for reference.
View attachment 9868View attachment 9869View attachment 9870
To do this mod you will need four bolts (5/16" X 1 1/2" Stainless Steel), four nuts (5/16" Stainless Steel Nylocks) and four to eight washers (5/16" Zinc Coated - couldn't find any SS).
First the brake side, the easy part.
Remove the rearset and keep the hardware, you will reuse them. Then install the set back plate. Note that the steel "teet" goes towards the bottom, not the top. The teet is used to keep the rearset solidly mounted to the setback plate.
A quick aside here, if you want to greatly reduce the amount of flex in the stock rubber mounting, simply flip the stock washers around BACKWARDS. This will give you a metal to metal contact and all but eliminate the flex, this is a free mod and will help shifting.
Once the set back plate is installed, install the rearset to the setback plate. You will need to readjust your lever as the setback plate rocks the rearset back just slightly. No big deal. I also recommend you use a drop of red LockTite on the threads.
View attachment 9874View attachment 9875
Now the tricky part, but not hard to do, the shift side.
Like the brake side remove the rearset and install the setback plate. I found that with this plate the "teet" stuck out too far to mount the rearset on flush to the setback plate. I shimmed between the plate and the rearset to make a solid metal to metal contact.
I read the posts from Mattcosta7 and afpreppie04 to help figure out the shift rod. http://www.600riders.com/forum/fz6-mods/9480-setback-plates-installed-gp-shift-swap.html
With this mod I wanted to keep the shifting standard whereas Matt choose to use GP shifting. You can choose which ever one you want, both work well.
I tired several combinations but here's what I ended up doing; putting a double bend in the shift rod. The bend is very easy to do and you do not need to heat the rod first.
To get this to work I eyeballed where the first bend needed to be and marked the point on the rod with a Sharpie.
Then I used two box end wrenches and my fence to bend the shift rod. (Yeah next year I'll buy a house with a garage so I can have a real vice.)
At this point you will need to begin "playing" with the fit. I removed the transmission shift shaft mount and flipped it backwards. Then I had to shim the rearset itself; Matt used washers between the setback plate and the rearset. Once I began to play with the set I now understood why he did that. Instead I decided to shim the shift lever itself, thus keeping the rear set towards the center of the bike. Note that I used one extra washer, not the two in the photo, one is stock.
After install, fiddle, test ride, do over twice, I got it. The bike rides great and shifts wonderfully. All in all the mod isn't too bad to do and give a much more agressive postion and greatly increases ground clearance. If I grind peg now I am going waaaaay too fast! :thumbup:
No I didn't, could have used them however. I just put them on this afternoon.
I bet they make a HUGE difference at the track! They are also great for those who simply want to change of the riding position a little bit. I guess you HAVE to sign of up for another track day now...no choice really. shucks.
those look great!!! Good looking mod and functional too. Let us know when you get them to the track again how you like them :)
Top Job Pete,
I love the analogy of "There are already some great wheels out there".
With that in mind,
Can you tell me the length of the shift leaver before you make your first bend and the washer size to make the shims?
I know it seems daft however, if I am lucky enough to score a set from louis. When I do the mod I would like all of the parts there and ready to go.
Thanks in advance mate.
Nelly
PS, I am guessing that it is essential to remove the center stand in order to utilise the extra ground clearance?
Top Job Pete,
I love the analogy of \\"There are already some great wheels out there\\".
With that in mind,
Nelly
Hi Nelly,
I used all stock parts except for the nuts, bolts and washer.
As for the shift rod I simply held the rod up and put a tick mark on it. I didn't measure anything; all eyeball. I was trying to make the rod follow the contour of the frame. As you hold it up you'll see what I mean. As far as the length of the rod I positioned the clamp on the transmission shift shaft towards the rear of the bike to shorten the length from there to the rearset. Like I said it took a few tries to fiddle it into place. The key, because I didn't make my bends sharp enough, was to use the washer behind the shift lever. The washer really helped with alignment.
Just give it a try and you'll get it. :thumbup:
There is one the day after Thanksgiving. If I can pull that one off I'll be hero!
The bonus is they have child care going on a shuttle bus to take the spouses to the outlet malls. Hummm...maybe.
Hi Nelly,
As for the shift rod I simply held the rod up and put a tick mark on it. I didn't measure anything; all eyeball. I was trying to make the rod follow the contour of the frame. As you hold it up you'll see what I mean. As far as the lenth of the rod I positioned the clamp on the transmission shift shaft towards the rear of the bike to shorten the length from there to the rearset. Like I said it took a few tires to fiddle it into place. The key, because I didn't make my bends sharp enough, was to use the washer behind the shift lever. The washer really helped with alignment.
Thanks Pete,
I will just have to wait and see if I am one of the lucky ones?
As for the centre stand I am guessing thats a no brainer. The trick is do you keep it off once its off.............
Nelly
Thanks Pete,
Nelly
I haven't put mine back on yet as I have a parking chock for the bike. The key stand to remove is the side stand. It is very low, about even with the "curb feeler".
Awesome write up Pete! BTW, the piece you are calling the "teet" I am told is called a dowel. Excellent work. Thanks again. And I'll be linking back to this from my threads.
BTW, I still have 6 sets of Black and I'm trying to get an order of Silver fabbed. If people tell me they're interested, I'll get some more Black fabbed up.
Awesome write up Pete! BTW, the piece you are calling the \"teet\" I am told is called a dowel. Excellent work. Thanks again. And I'll be linking back to this from my threads.
Thanks Louis, I'm glad I finally got them installed, BIG difference. Thanks again for making these. :thumbup:
Can't wait to get mine, unfortunately i am not a mechanic and have to pay to put this on. So i will buy the bolts and stuff and see how much they will bang me over the head with.You win some lose some. Or do you think it is something i can do with all the notes from you guys?
