Dresnewtoy
I have the '08 model. When i was doing the headlight mod and needed to lift the tank a couple times. I found that i had to pull on the fairings to get lift the gas tank up, past it (the tank is a little wider than the space between the fairings).
I looked like removing the fairing was a lot of work, but yanking on them on a regular bases might strain or eventually break the fairing.
How do you guys go about lifting the tank??
