Leo Vince Installation question
mikexup
Howard, OH
Installation went pretty much uneventful, however the tail section is aligned less than perfect. Is there a way to correct this without taking the whole tail section of the bike back off:confused: It isn't terrible ..in reality most people wouldn't even notice, but I know it's there.
May Be able to try loosening the bolts under the seat around the T section and see if there is any play there to try shifting things around a bit. Depending on your misalignment issue, it is usually best to keep most of the bolts loose that you can to get it the way you want and then tighten. Hope that helps.
When installing my LVs I had some alignment issues as well. A mentioned, leave all bolts slackened until you're satisfied, then tighten them by pairs. Also, for me the majority of the alignment issues were from the straps holding the slip-ons proper, not from the bracket itself. Have patience, it'll come together in the end, and they'll look awesome. :thumbup:
Sent from my SAMSUNG GALAXY S2 INFUSE using Tapatalk 2
