Thanks wolfc70. The more that I think about the gear thing it seems to be the only thing that makes sense. The metal is magnetic as far as that goes. Seems that if there was a problem with a bearing sheding that much metal I'd know about it by now. Anything that falls into the pan settles and is filtered before being pumped through the engine so further damage should be minimal. I would guess it possible for the lower gears to shear and wear in for a while as most of the load is transfered through 6th gear since I mainly commute on the highways. I think at this point I will consult a dealer (when I can get there) then decide what to do. Might be best just to monitor - or at least pull the pan to see. Perhapse I panic to easily... I hope
. Thanks to everyone for the input. :thumbup:
I personally would not visit the dealer. Since the metal was magnetic, and that much metal off a crankshaft would make catastrophic nose, it is gear wear. Change the oil and filter in a few hundred miles, I bet there will be little if any shavings. I suspect that the filter was not changed when it should have been. As a side note, I change the filter when I change the oil. Since gears always wear, there will be metal particles in the filter and going 8000 miles on a filter is too long IMHO. The $12 USD spent on a filter every oil change is cheap insurance that the oil stays as clean as possible.
