Nelly
International Liaison
Co Offaly, ROI
Hi Guys,
Im having a bitch of a job removing my front axel.
Can you confirm its counter clockwise to undo.
Cheers,
Nelly
It's been a while since I had those forks on, but it should be the standard lefty loosy righty tighty. Do you have the pinch bolt loose?
Cheers Joe,
Pinch bolt undone, I have lost my socket that I could put the extension bar through. It is stuck like a mofo. My DID chain breaker is the right size and leaves me enough room to get a 19mm spanner on it but that bastard isn't budging. I cant find a plug spanner in town to fit.
I tried the bolt with three locking bolts and that sheared off.
I need to find a socket.
Nelly.
I went out and purchased some socket adapters (like this one Bosch 1/2 in. x 2 in. Impact Tough Socket Adapter-ITSA12 - The Home Depot) that allow me to connect sockets to my Makita impact driver. Whenever I have something that is too tight and robust enough to withstand a mild beating, I use the impact driver to do the initial. If you have an impact driver, you should be able to find the adapter.
I used to use a 1/2 inch threaded rod connector, available cheap from a hardware store etc. It fit right inside the the axle. you can then use a 1/2" drive breaker bar with a 3/4" socket on the connector. :)
shopping
Solution, I contacted Kevin Casey Junior of KC Motorcycles. He is such a top bloke I asked if he wouldn't mind breaking the bead for me and then I could ride home. So brought the bike down, The guys broke the bead and I road home. Forks now off and draining. Oil completely silver, I suppose that's what happens when its 10 years old. I'm putting 15w oil back in as I always hated the dive from the front end.
Nelly
Nelly
You may want to try 10wt, Neil. 15wt is pretty thick.
To late mate its in, but being the intrepid mechanical guru that I am (not) I measured the oil which stated 500ml on the bottle into a jug on my digital scales it weighed 440ml, I then poured water into the empty bottle up to the 500 ml mark and there was only 460 in the jug WTF? so I poured it all in as the bike needs 463ml.
I made a gadget to undo the Axel when I got in using a bolt and three locking nuts. I will let you know after the test ride.
By the way, the left fork leg had only half the oil of the right leg.
I also discovered you can drain the forks from the bottom without the need to remove them from the bike. I removed mine completely and cleaned the legs of any surface debris and rust.
You know modern auto manufacturers use this stuff for their suspension and its tagged magnetic ride control.
You should sell it; I mean it took 10 years to make it, right?! Blah
So having put a few hundred km's on the new fork oil I have to say I'm delighted I weigh 82kg and the dive is very much better under hard breaking.
I plesant bi-product I have noticed is that the throttle jerk is not as noticeable. The caveat of course is that I was running stock old oil with only half the amount in one leg.
I'm happy with the change so for me it was well worth doing.
I can't post bloody pictures, tapatalk crashes every time.
