Oh yeah, one thing I'm experimenting with is the oil level. When the new oil went in, with the forks compressed under the bike's weight, I topped right up to the washer then weighted the rear to let the forks extend before putting the stock spacer tube back and screwing the caps on.
I am of course much happier with the front with heavier oil and I'm quite light (under 12 stone), so......
Thing is I'm not sure what the effect is of upping the level a little over the recommended.
Ideas? Opinions?
Do tell.
I was in exactly your position around a year ago, since then I've done plenty of research and have tuned the suspension on my FZ6 with the knowledge I‘ve gained, so I hope I can offer you some advice/guidance.
To answer your immediate question (switches into engineer mode :thumbup
, the air trapped within the top of the fork can be considered a form of progressive spring, changing the size of the air gap allows you to adjust the progressiveness of this 'air spring', this mainly influences fork action within the bottom third of the suspensions travel.
The smaller the air gap, the more each unit of air trapped within the fork is compressed per unit of suspension travel, hence a smaller air gap will provide an air spring of greater rate increase per unit of travel than that of a larger air gap.
Basically, this can be used to optimise the amount of travel used, effectively providing a progressive bump stop toward the end of travel, however FZ6's from '07 onwards have a hydraulic bottom out fitted (not sure about the '04-'06 models), so this is not overly important as the hydraulic bottom out prevents you from getting anywhere near actual mechanical bottom.
I'm currently using a 115mm air gap, this is mostly to try and provide some assistance to the quite lacking low speed compression damping of the FZ6's forks. I'll spare you the full explination just for now as it's quite lengthy, however I'm more than happy to explain if you would like. As a general rule, your maximum decrease in air gap should be around the 20mm mark.
Dave Moss of Catalyst Reaction has made many videos on the various areas of motorcycle suspension tuning, I strongly recommend that you spend time watching them when you can (they're a little lengthy...), here's a few to get you started:
[ame="http://www.youtube.com/watch?v=mK3flKxf41U"]Motorcycle Suspension - Setting Sag - YouTube[/ame]
Dave Moss Insprung: Setting Sag, Dave Moss and Dave Williams talk about properly setting sag on a motorcycle. OnTheThrottle on USTREAM. Racing
Dave Moss Unsprung- Fork Springs, Did you know there are such things as linear and progressive springs? Do you know what is in your bike? Do you know how t...
The rest of the videos from that series are also available on that UStream channel, and segments of his series 'two clicks out' are available on YouTube, just shout and I can post you some more links. :ban:
Hope this helps you out, if there's anything else you think I might be able to help with please ask away. :rockon:
Yamahaboyz
