Iron Cross
So about a month ago I hit a patch of gravel and dumped the bike...(first outta the way hopefully!) I cracked a side cover, the headlight mole, and the crank case cover. All of which were a little scratched up from the previous owner, I just made them worse.
I replaced the mole and the side cover without a hitch. Except that the mole isn't exactly sitting in its spot well (I think from the two dumps, me and the previous owner, that somethings bent) and don't really know what to do with that.
Then there's the crank case, which I can replace, at around $60.00 I've found (unless anyone knows better). I can paint it, but the paints almost as much as the part. Or I can use cheap paint just to see how it looks, then replace if it sucks. Also, if I take off the case is it sealed and filled with oil? Don't think so but not sure.
Thanks for any help guys!
