Kriswithak
So I put my pazzo's on and have been playing around with the clutch adjustment at the handlebar. (the screw thingy - not the lever tab)
The actual reach on them now is absolutely amazing and great, but the problem I'm having is I don't think there is the correct tension in the cable and its not properly engaging/unengaging. I've been trying different adjustments without much luck! Something just doesn't feel quite right!!
I tried to fix it up and when I was at work today the bike was actually trying to roll forward really really slowing with the lever all the way in!!!
I put it to the other extreme which helped a bit, but it doesn't engage as cleanly.
How do you know where they should be at tension wise so your engaging the clutch properly??
