ok guys! some news.
1. we realigned cams. here is before pic:
Imgur: The most awesome images on the Internet here is after pic:
Imgur: The most awesome images on the Internet so the intake cam was ok and the exhaust cam was off
2. I broke a bolt, one of 20 by which cams are being held in the engine. It came out nicely for some reason but it will take some time to craft/buy a new one. So no video of starting engine today.
3. answering some questions:
>.With cams off, it can get fuel, BUT the engine is firing the plugs at the wrong time, it WON'T RUN.
one cam was off, but it was an intake one. so the engine will fire plug at correct time - on top of TDC. Thats we dont get, why it does not even try to do it.
>Do a compression test. Rent a gauge if need be. There is no point in taking it apart if it has compression!
I believe it has compression. When I rotate crank by hand its really hard to turn it at TDC mark and engine makes some puffing noise but after TDC piston goes down and its easy to rotate. My brother said that I'm building compression by hand thats why its so hard.
>As stated; dry plugs and add fuel manually into the TB openings. A splash in all four. This solves ONE of the three mysteries... If it fires off we know IT can run.
If it has compression, and we KNOW its either spark or fuel. Adding fuel solves that part of the equation IF THE PLUGS ARE CAPABLE OF LIGHTING THE MIXTURE...
Last time we got out plug #2 and #3, they were wet and we dryed them. Did not spash a fuel there though.
My friend with the same problem tried new sparks, old sparks, dried new and old ones - did not help.
>Did you unplug the coils power and ground wires? Y/N?
You mean that cylinder looking things that are hosted on the battery and are wired to the plugs? If its that than no, we just unscrew them from the battery and let them hang. Also we checked the spark using some old plug - there is a spark.
