Breaking in a new Bike- Hard? or by the book?
(none)
Not even here
cincinnati
I've worked for an auto manufacturer before (who also produces motorcycles), be assured that no one who has ridden the bike before you cares about the "proper break-in", so you probably really shouldn't bother either. As long as the motor is up to temp and has good oil with pressure, ride it however you want to. When is the last time you heard of a motor in anything having a problem that was blamed on it being broken-in improperly? Never.
My favorite story to tell people who talk about this is the first time i was at an auto plant, watching the production. A car is driven right off the line, out the door, up to an intersection. The driver stops the car, puts the car in neutral, then floors it. The thing is bouncing off the rev limiter, the driver drops the car into drive. The car sits still, it is a test to make sure the car doesn't go into gear when reved above a certain rpm. The rpms drop, car goes into gear, driver tears off down a short course to test some stuff, then the car is parked in a huge parking lot and he goes to the next car.
madmanmaigret
Mad like crazy not angry
Sarasota, FL
I would say, stay away from long trips at the same rpm and you should be good. You won't know what you bought until you see redline! :eek:
fast blue one
The number of the beast
Stevenage
I broke mine in by the book (ish).
One important thing is to make sure you get up and down the gears a lot. :thumbup:
hazy
Singapore
I just rode my bike as usual style.But i will tried to avoid the highway if possible for the 1000km.
bmccrary
Touring Mod
Lexington, NC
Every Honda ATV that roles off the line is run on a dyno first thing. The first step, wide-open through all gears...
I like to heat cycle my motors, but I have heard and understand both sides of the arguement.
-bryan
Gilo-FZ6
Riding the Big Honda
Premium Member
Cardiff,SoWal
ive owned 3 bikes with 0 miles ..all ridden hard and fast from the off,,no problems here
bigdog9191999
High-tech Redneck
southwest michigan
my dealers have always told me that the factory way was good if not a little conservitive, meaning follow the basic guidlines of no high revs and to varry the rpm and no consistant rpm other than that just ride it "normal"
FLuK28
Toronto, Ontario
-bryan
Thanks man! After reading the article that I posted, alot of what he said does make sense.
