Once again guys, thanks for your input.
Lets get started, dont want an R6, if i did i would buy one. Have ridden Sportsbikes all my adult life till recently, but bought FZ6 with a few things in mind.
1. i have a bad back, shoulder (as a result of a rather nasty highside on my Ducati), and have bone spurs & arthritis in my neck - t4, t5, so riding a bike with an ultra aggressive "racing" stance is agony within half an hour of riding.....can ride the FZ6 all day without any discomfort...
2. I have a son who regularly rides pillion, and a Sportsbike is not the safest, or most comfortable option here.
3. I need to carry a fair bit of gear, on regular occasion.
4. I dont like fairing's, even my Ducati only has a bikini fairing.
5. I love the naked look!
So i bought the FZ6 as i still wanted a bike with a strong motor that could keep up with a lot of Sportsbikes in the Twisties...only problem is, Mr Yamaha obviously decided that FZ6 riders dont care about going around corners! So i set out to fix it myself.....
That's where we are at now.....
Ok, Sag rates for front and rear are 25mm respectively, Front & Rear shock spring weight is 9.5kg, which is a considerable increase over the 8kg spring on a OEM FZ6 shock. I weigh 108kg's
, currently rear shock compression is set at about 80%, but rebound damping has been kept at about 60%.
Since my ride last weekend with a near bald trye....(was completely screwed after 400km's last weekend), and since i experienced such crappy handling on this ride due to the rear misbehaving...which was more pronounced than usual, as the mechanic did stiffen the front a little more at my request, when we changed forks last week!
Since this ride, i have decided to fix this problem, have upped the rebound damping by about 4 clicks, and fitted the taller, and surprisingly, much rounder profiled, stickier 190/55 piolt power 2ct (replacing a 180/55 pilot road 2ct).
As i said, i have only been for a quick blat, but immediately, bike feels much tighter in the rear, and in fact seems much quicker to tip in again......signs that the new back tyre has helped, and that more rebound, has settled things down a bit....if after my ride on Sunday, i am still having issues, i suppose there are a few things we can do, or conclude.
1. Maybe the front is too stiff?
2. Maybe the rear spring is not heavy enough, and i need to change to a heavier spring
Am thinking at this point that i may be close to sorting it out....other thing to consider is that i still have a Pilot Road 2ct on the front of the bike, and there is a small concern that with the rear having more grip than the front, that the rear tyre could also now push the front......have a Pilot Power 2ct front sitting on hold at the bike shop, just in case....
All i know is that i am having lots of fun learning about my bike, and how it behaves.
I am sure that by the end of this i will be able to get to the point where i can make finite adjustments on the go, centred around my many varied needs..such as different loads (Pillion, Pillion & Gear, Just Gear, Sport, Commuting) which was the point of it all to start with.
I love my Fizzer. :rockon:
