DefyInertia... would the clipons clear the fairing of a 2005? I'm really tempted to switch to clipps but i dont want to dish out 200$ and then find out they hit the fairing
Yes, helibars or blackbird clipons would. mbodell, gosling, and a few others have faired pre2007 bikes with clipons.
Tank clearance is almost a larger issue.
From what I recall he removed his fairing for the clip ons to clear. Remember he did have them on the top of the top clamp and then moved them below the top clamp. The move to the bottom of the clamp will give you even less clearance with the fairing.
DI - please correct me if I'm off base.
Yup, tank clearance is the only issue on the pre2007 bikes (no idea on the 07+). That is, so long as you're willing to mount the clipons above the top triple.
I removed my fairing via a crash at the track and the clipons came later.
I moved them below because the geometry was too screwed up (for track use, IMHO) when they were above.
How far did you have to drop the forks down or is it raise them through the yokes? Have you had an comfort issues on longer runs Defy? You are probably one of the tallest members.
I can do whatever I want with the forks at this point; they are not affected by the clipons (because I'm naked).
Comfort issues, no.
I can do a 300 mile day of twisties with no problems but buring out 500 miles of highway or something would probably suck. The key is to keep the weight off your wrists by using your core (this takes some getting used to).
All that said, it all depends on the rider. Gosling who has done 55K+ miles on his 2006 prefers clipons over the handle bar simply for comfort...I, on the other hand, would probably prefer the handle bar if comfort was the only consideration.
Hey Pete,
Forgive me if I am wrong, didn't Eddie Lawson's flat tracker have a straight bar? Boy could he turn that bike in.
I am really struggling to see how the bar makes it easier to get off the bike.
First, a flat tracker is very different than a modern SS and what you're doing with them is very different. I don't see how that is relevant here. And with regard to motorcycle road racing, a lot has changed there...you really don't see anyone in MotoGP using anything but today's "textbook body position".
Clipons allow the rider to get down and inside without bending their wrists soooo much that they compromise their ability to make smooth/precise inputs. They simply make MORE body position possible.
Clipons also give you WAY MORE feedback.
None of this really matters at a street pace.
Thanks Pete,
It does make sense. I personally think that rider agility is more important than bar position. When I first got my bike I was about 14lb heavier than an now. I found that trying to hang off when I was a fat chap near on impossible.
To a point, it won't matter, but you can't drag elbow with a big honkin handlebar on there, get it? :thumbup:
