5100 vs 7100, oil change
Zealot
The Village Idiot
Canada, Ontario(GTA)
12-15 ft lbs is plenty for both the filter and drain plug..
Went with a torque wrench and followed the manual for both of those. I seem to recall some sort of reading about the drain plug text being wrong, and you oughta set it lower lest you risk a cracked pan or something, and set it a few ft-lbs lower accordingly.
The manual calls for 30 ft lbs.
I have the exact same drain bolt, in an aluminum block in my Yamaha F150 HP Outboard engine. That SAME BOLT, calls for 20 ft lbs..
Double click to enlarge;
Zealot
The Village Idiot
I set it to like, 25 or 26 so I'm not too worried. Definitely not anywhere close to as tight as how the previous owner had tightened it...
Love@FirstRide
Montrose, Colorado
Just switched from Mobile 1 i put in when i got the bike to the Mutol 7100 and wow the shifting IS SMOOTHER! I'm very very happy i did this. with a k and n oil filter was 62 shipped.
Yepper! Now, if you hold in the clutch lever for 4-5 seconds before going from neutral to first gear, You'll lessen the gear clunk as well.
I have my idle set at 1,100 so the first gear clunk is negligible...
ErikNYC
Earth
Good to hear.
Check out revzilla for you oil, about $35 shipped. And eBay is about 12 shipped for the filter.
