Zanch
Estimated Time: 20-30 minutes if you're really slow
Applies to:
All FZ6 Years produced for the USA
What you need:
Yamaha's tool kit that came with the bike or appropriate tools.
Some thin wire ( I used 18awg solid core but it doesn't really matter)
I also used two pairs of pliers to pull the connector in question apart.
Why I made this:
As you may or may not know, there is a Co adjustment built into the FZ6 and other Yamaha's that supposedly allows you to richen or lean out the air fuel mix. Since I have Scorpion exhausts and they tend to lean the bike out / you can get more power if you do the Co adjustments... I've made this for the community.
Special Thanks:
I would like to thank krid80 for his information on the subject. I decided to make this because it was way to hard to search and find the information on this.
Instructions:
Applies to:
What you need:
Why I made this:
Special Thanks:
Instructions:
- Remove Tank
a. Remove the hinge bolt with the included bike ratchet
b. Remove the 2 allen screws with a 5 mm allen wrench
c. prop the tank up on the handlebars or however you feel comfortable - Locate Harness
It will be near the frame in the red box note that it's directly under the tank.
Lets take a closer look...
Notice the connectors. You're looking for the semi clear 6 pin connector. In this picture it's the one in the back behind the white connector.
Here's the connector you want all by itself. - Pry the connector apart. It will be tough but it'll come apart. I used a pair of pliers and a flat head screw driver to loosen the connector
- ground the wire - You will be grounding the wire that isn't connected to anything. It will be yellow with a red stripe and brown splotches
I stripped off a good amount of insulation and just stuck it into the yellow terminal. I then plugged the connector back together. You can then connect the other end of the wire to either the negative battery terminal or anywhere on the frame.
- Test the results! - Now it's time to do the adjustments
- G8anos's Instructions for Adjusting Co
1. We push at the same time the SELECT + RESET and keep them pushed
2. We turn the key to ON while continuing to keep our buttons pushed SELECT + RESET
3. Wait 3 to 4 seconds to show us in the speedometer DIAG and stop pushing the SELECT + RESET buttons
4. We push the SELECT to show the CO
5. Hold the SELECT + RESET to show us the C1
6. Hold the SELECT + RESET to go into C1 which shows a number that is the regulation of the current mixture in the cylinders 1st + 4th think (mine was -2, note the number you have in case you want to reset)
7. We push SELECT to add fuel, while RESET to remove
8. Hold the SELECT + RESET to get out of the C1
9. We push SELECT to display the C2
10. Hold the SELECT + RESET to get into C2 which shows a number that is the regulation of the current mixture in the cylinders 2nd + 3rd think (mine was 8, note the number you have)
11. We repeat ,as on step 7 (Add fuel)
12. Hold the SELECT + RESET to get out of the C2
13. Close the switch by turning the key to OFF
The official Instructions
- Krid80's Results
Run 1 (stock tune) - 93.20hp
Run 2 (+4 C1 and C2) - 93.82hp
Run 3 (+9 C1 and C2) - 94.77hp
Run 4 (+14 C1 and C2) - 95.11hp
Run 5 (+19 C1 and C2) - 95.60hp
Run 6 (+24 C1 and C2) - 95.79hp
Run 7 (+29 C1 and C2) - 95.681
