S
shuangshuang
I like it.:rockon:
I was hoping to get to ride some this weekend, but pulled my bike out to get it out of the way of the one we have for sale and noticed fluid dripping. Gotta replace the flipping water pump now. I am crushed. I'm in my last semester at school and it is all clinicals. Due to insurance requirements I am not allowed to ride to my clinicals. So the weekend is pretty much it for me right now. This sucks!
I bought a an OEM replacement key as a spare. My used bike only came with one key. Do they normally come with two? I would expect they do. Cheap insurance plan in my opinion in the case that I lose my keys on a ride somehow.
If you can operate a screw driver and a ratchet, order the seals and bearings and take the pump to a bike shop. I bet they'd charge you less than an hour to pop new bearings and seals in. Bolt it in, connect hoses, add fluid and your done.
Please do clean and check - make sure its not just a hose seeping!
2008 R6S - YZFR6SXCB Yamaha Motorcycle WATER PUMP Diagram and Parts
OK - People I'm seeing a trend here - FZ parts are being discontinued by Yamaha.... Yikes!
SOME WATER PUMP PARTS BEING DISCONTINUED!
15EB-12421-00-00HOUSING, WATER PUMP$88.27$88.271NOT AVAILABLE
293306-00106-00BEARING$0.00$0.001NOT AVAILABLE
393101-12173-00OIL SEAL$0.00$0.001NOT AVAILABLE
411H-12438-10-00SEAL, MECHANICAL$0.00$0.001NOT AVAILABLE
55EB-12450-00-00IMPELLER SHAFT ASSY$31.99$23.641
65SL-12422-00-00COVER, HOUSING$61.99$40.831
75EB-12439-00-00O-RING$8.99$6.171
895024-06020-00BOLT, FLG.(SMALL HEAD)$2.07$1.342
990430-06014-00GASKET$0.00$0.001NOT AVAILABLE
1099009-12400-00CIRCLIP$0.00$0.001NOT AVAILABLE
1193210-33133-00O-RING$7.37$5.191
1290110-06149-00BOLT, HEXAGON SOCKET HEAD$2.11$1.582
134NK-12579-00-00HOSE 4$5.99$4.101
145EB-12581-00-00JOINT, HOSE 1$43.99$28.951
155EB-12577-01-00HOSE 2$15.99$11.481
1690450-35001-00HOSE CLAMP ASSY$0.00$0.002NOT AVAILABLE
175SL-12588-01-00HOSE 5$3.99$2.311
1890450-22017-00HOSE CLAMP ASSY$8.24$8.241NOT AVAILABLE
195GV-1246E-00-00COVER 2$2.99$1.561
2090450-38040-00HOSE CLAMP ASSY$0.00$0.001NOT AVAILABLE
215GV-1246A-00-00COVER 1$2.99$1.441
2290450-32001-00HOSE CLAMP ASSY$7.81$7.811NOT AVAILABLE
2393210-46001-00O-RING$4.23$2.591
245EB-12469-00-00JOINT 1$39.99$29.251
2590105-06053-00BOLT, FLANGE$1.60$1.602NOT AVAILABLE
