As promise, here's the number I have for the 04 FZ6 cams.
IVO: 45 BTDC (6 @ 1mm)
IVC: 78 ABDC (35 @ 1mm)
ILC: 104.5
(180+6+35) /2 -6=104.5 degree
EVO: 60 BBDC (40 @ 1mm)
EVC: 27 ATDC (5 @ 1mm)
ELC: 107.5 degree
I do not remember the total lift of the cams. But that can be found in the FZ6 manual. (max lobe measurement - base circle)
Hope it help. Those number could be a snug different on the FZ6... that's what I was hoping to find also. Since those are about the same numbers as the 07 R6. My educated guess would be to compare the FZ6 and R6 cam gears. Maybe the only difference is the way the cams are timed. You will be amaze what 1 or 2 degree does. (.006" slot in the cam gear is about 1 degree... give and take)
Digging up the past cause I'm playing and connecting a few dots.. .. ..
Item #1 = Intake PN: 5VX-12170-00-00
5VX-12170-00-00 CAMSHAFT ASSY 1
ILC: 104.5
Item #2 = Exhaust PN: 5VX-12180-00-00
5VX-12180-00-00 CAMSHAFT ASSY 2
ELC: 107.5 degree
Item #3 = Gears (I & E) 5VX12176-00-00
5VX-12176-00-00 SPROCKET, CAM CHAIN
94591-49120-00 CHAIN
5SL-12210-10-00 TENSIONER ASSY, CAM CHAIN
INTAKE CAM where used:
2004 FZ6 - FZ600SS, FZ600SSC
2005 FZ6 - FZ6ST, FZ6STC, YZS6T
2006 FZ6 - FZS6V, FZS6VC, FZS6W
2007 FZ6 - FZS6W, FZS6WC
2008 FZ6 - FZS6XBC, FZS6XB, FZS6XLC, FZS6XL, FZS6XCB, FZS6XCL
2009 FZ6 - FZS6YB, FZS6YL, FZS6YL, FZS6YL
EXHAUST where used: (Same as above)
2004 - 2009 FZ6
GEARS where used: (Same as above)
2004 - 2009 FZ6
ROTOR where used: (Same as above)
5VX-81673-00-00 ROTOR
2004 - 2009 FZ6
PICK-UP ASSY where used: (Same as above)
5VX-81670-00-00 PICK-UP ASSY
2004 - 2009 FZ6
2014-12-01 - new info, Race cams for the R6
http://www.r6messagenet.com/forums/pdf/03-04R6_race_manual.pdf
04 YZF-R6 SS KIT MANUAL
3 5SL-12176-70 SPROCKET, CAM 1 1 105° << keep an eye out for OEM multi position gears
4 5SL-12177-70 SPROCKET, CAM 2 1 110° <<>> 5SL-12177-80-00 IDK?
• Use the cam sprocket included in the kit for aligning valve timing. The cam sprocket included in the kit allows selection of five valve timings. In the case of aligning for the purpose of attaining a minimum squish height of 0.60 mm, use of the center mounting hole allows setting for intake valve timing of 105° and exhaust valve timing of 110°.
• Valve timing adjustment range can be changed to either ±1° or ±2° relative to the center mounting hole.
CAMS that might be in circulation:
5SL-12171-70 SHAFT, CAM 1 1 INT.296
5SL-12181-70 SHAFT, CAM 2 1 EXT.284
Working angle: I 296° | E 284°
Valve timing (sprocket): I 105° | E 110°
Valve clearance: I 0.17 – 0.23 mm | E 0.27 – 0.33 mm
Cam lobe:
INTAKE:
a: 33.45 – 33.55 mm Lift
b: 25.16 – 25.26 mm base circle
= 8.3 mm lift
EXHAUST:
a: 32.55 – 32.65 mm
b: 25.09 – 25.19 mm
= 7.46 mm lift
