Vibration! A cure for bad vibrations, Spark Plug Caps!!
Yep R1 coils would also work. Only ones to avoid would be the earlier R6 coils which were CDI, and have a lower primary resistance. You'll be looking for something with a primary resistance around 1.19 to 1.61, so when it's wired up in series it'll be closer to what the ECU is used to seeing, and won't cause any issues with the transistors. MT07, MT09, FJR1300 and R1 coils are safe, but if you can find out the primary resistance then you'll know for sure if it's suitable.. Not sure about other brands.
You are EXACTLY right.
Hi everyone,
Firstly a disclaimer- Don't try this mod, it's still experimental and if you try it and your bike breaks down then I'm not responsible!
I've been working on a project on my bike, which was suffering from vibes for a long time. I had tried working on cutting the leads back, which worked kinda sorta, but not that well. Then I tried replacing the leads with some newer HT leads, but the issue was getting a reliable connection on the coil end. I had looked at the idea of Coil on Plug, and read a lot online about other bikes where owners had swapped their wasted spark coils for a wasted spark COP setup. There is a thread on an FJ1300 forum which details the conversion, as do several others, but many forums have been crippled by the whole Photobucket debacle which has made it hard to find detailed photos.
I decided to buy 2 COPs from a Yamaha fz07, just to try and see they'd fit. I found they fitted nicely from the top with the tank and airbox removed. I then ordered two more from a Yamaha FJ1300 from ebay and also a wiring harness from a Kwaka Z750. I stripped the wiring out of the loom and rewired it in series. Coils 1 and 4 were wired in series for one coil connector, and coils 2 and 3 were wired in for the other connector. Primary resistance went up from stock values of 1.53-2.07ohms to around 2.5. I checked the original coils and they were really low (out of spec) so that could have been the cause of my vibes, combined with the HT leads.
Anyway here are a few shots.
The bike fired up straight away once I finished the wiring and put everything back together. I ran the bike in the shed for a while then took it for a ride today and was impressed with the results. It ran cleanly through the rev range without any issues and the vibrations were gone. I could have easily picked up a second hand set of coils off ebay but I wanted to try something different and move away from HT leads altogether. From a technical point of view I was concerned if the coils would still fire the plugs cleanly at higher revs as the coils are firing twice as often in the wasted spark setup compared to the bikes they were designed for ( FZ07 and FJR1300) but the coils haven't had any dramas so far. I made up a wiring loom with spade connectors to plug straight into the factory loom. I looked at the option of wiring the coils in parallel but that would require a 1ohm resistor to pull the resistance back to what the ECU is expecting, so there isn't anything to be gained, in fact I did some calculations and worked out I'd have less power at the coils.
Anyway as mentioned it's still an experiment but so far the bike feels great with hardly any vibes in the 6k upwards rev range.
Enjoy...
Buzzbomb.
How has your bike been running since you did the change any problems yet
I had problems with my coils (after 20 minutes of highway I lost 1st and 4th cylinder, worked again when cooled off) so I tried the COP conversion since even my spark plug caps looked off. I bought 4 cheap COPs for R6, I checked the resistances and all matched and put them into my bike. The bike ran flawlessly when started. No vibrations and quiet. I took it for a ride and didn't find any problems, but after few minutes it stalled on me once I stopped. Then it was stalling 5 seconds after starting the engine again. I had a little bit of problem to start moving again, but once I was moving everything worked flawlessly. I raised the idle to 1400rpm and It was managing to stay on most of the time, but the idle was incosistent when warm (flawless when cold). I changed the oil, fuel filter, adjusted CO values but nothing helped. I swapped the old coils back and the misfire dissapeared.
I took a gamble on cheap COPs and lost, but at least now I know how to dissaseble the bike.
I successfully did the COP mod on my 2005 FZ6, using FZ07 coils. According to Buzzbomb (where I got the idea from), you need to avoid certain R6 coils as they are CDI. If you are going to replace your coils, you might want to look for FZ07s.
Hi,
I'm also having bad vibrations problem on 2011 FZ6R (XJ6 Diversion F). Vibration start at ~4.5K RPM, even on stationary bike in neutral. Felt all across the bike: handlebars, gas tank, footpegs etc. Stronger on right side. Bike is at ~55K km ODO, I bought it 4 years ago at 36K ODO and problem started Spring 2025.
I followed OP guide to re-cut HT leads and tighten the contact with cap boot. Threw tiny wormgear clamps over them for good measure. Attached picture are resistance measurements I took after all manipulations with coils & caps. They should be on spec, but as this seems to be such a prolific problem on the bikes, I am still suspicious. Do you think it is worth it to replace coils?
Other than that, I had a shop do valve lash adjustment/sync, did my best to do TBS afterwards (idle is OK, but at 4K RPM - I gave up), tested for vacuum leaks, did a $ bill misfire test (OK), replaced injectors, air filter, lambda (oxygen) sensor, spark plugs (iridium, 0.7 gap), cleaned fuel filter (new one on the way), tightened engine mounts. TPS goes smoothly in diag menu from 16 to 90, there is appropriate cable slack ~2-3mm at the throttle bodies connection. Oil is currently 10W-50 Motul. No errors in diag menu other than from removing airbox to access injectors and stuff.
At this point I'm most suspicious of these points:
  1. Cam chain/CCT wear, mechanic showed me how chain has ~5mm of play between cam shaft sprockets. Said it's okay for now but should be replaced next year, together with CCT.
  2. That I somehow messed up TBS, despite setting all 4 cylinders at ~21-22 cmHG at idle ~1300RPM
  3. That coils/contact are somehow still bad despite measuring on spec.
  4. That TPS is bad. It only goes up to 90, but smoothly without any other issues.
  5. That engine mounts are bad. Previous owner installed sliders upper rear engine mounts, and bolts have right thread pitch but not exactly right depth: 41 & 36 instead of ~45 OEM. I don't know how well it can be seen on this picture, but 10mm bolts also sit in 12mm frame hole, there's a ~1mm gap around bolts. I didn't know if it was supposed to be like this, so I've inserted aluminum washers/sleeve to size. The mounting points of frame that go to the engine also look really bad. They're spot welded in only 2-3 places and I can stick a paper under them. Not sure if this is normal.
I should note that acceleration is smooth, but seems worse now than it used to be when I bought this bike, but I might be imagining as I got used to it.
Also after cleaning fuel filter & replacing injectors, I was not able to pass CO2 exhaust test,. It was ~5.05 when in 2025 they measured it 0.69 and gave me a pass. I ended up dropping C0/C1 in diag menu all the way down to -70/-70 to pass. Default values that came with bike are C0=5/C1=6, and it runs badly on those now, requiring at least 20/20 to turn on smoothly from the first crank.
Please let me know which points you think are most worth further investigation, or if you have any other ideas!
As I was reading the first posts I was trying to understand how the connection is made between HT cable and the cap. There is a reversed, wood type screw in the cap, with its nose pointing towards the cable. As you twist the cable clockwise the screw is ..screwed in the cable's center, touching firmly (at least supposed to be firm) the stranded conductors of the cable. This is problematic by design. I have an idea but I won't say anything before I try it.
I removed the cap, sprayed contact cleaner at both ends and measured it at 10K. I I fitted a new spark plug to the cap and measured cap+ plug at infinite. Removed plug re fitted 5-6 times, the same result. Once I managed to measure 24kohms. I removed the inner parts of the cap using a 10mm flat screwdriver. The end socket that connects to the plug was quite dirty, spaying just from outside is not enough to clean it. After thorow cleaning I put it back and measured 15kohms cap+plug. This means we have to double check both sides of the cap. The final verification is done by fitting both plugs at the coil and measuring from center pin of one plug to the center pin of the other plug (on the same coil obviously) 5k + 10k + 15k + 10k + 5k = 45k ohms approximately. My coil has 15k secondary resistance, yours may vary.
Spark plug = 5kΩ
Cap ceramic resistor = 10kΩ
Coil secondary resistance = 12-18kΩ
To re-fit the HT cable I cutted 2 or 3 small pieces of thin copper wire and inserted them together with the cable's inner strands to make less room for the screw so it will fit tighter.
There is a connectivity issue at both sides of the caps. Measuring with the multimeter the cap is not reliable test because the dmm leads connect easier to the caps end terminal. Put a plug and measure both together to be sure.
One more thing, the dust cover on the cap has only one correct position determined by a protruding ring across the cap. When you slide the dust cover it clicks in the specific position.
Great work! One thing I think about in regard to adding that copper strand to increase contact with the screw. If the high tension wire is aluminum and you add a piece of copper wire, you may end up with a problem because aluminum and copper don't play well together. Galvanic reaction and dissimilar physical expansion with temperature change are the main factors. It may never be a factor but is a consideration.
I was wondering if there is a way to replace the HT cables with something better but I m not sure how they are attached to the coil side. I chickened out messing with it, I need the coils to try them (just got them from ebay) for my intermittent spark (and starting failure) issue am facing.
Yeah #4 looks much colder than the rest, same on my bike except difference is smaller around 40°C. I haven't figured out the reason myself either yet.
I wonder if adjusting the CO settings would make a difference?
Or maybe it's a fuel flow issue?
I repeated the measurement having a high temperature tape so all 4 surfaces have the same reflection characteristics. The temperatures seem closer now. Check the vid and tell me your opinion. I do have the sense of existing misfire even though I am not experienced at all on this, I am planning to to a TB sync myself (tool is on its way) as I had discovered that the calibration hose of cylinder 3 was cut and the mechanic probably did the sync on February with a leaky hose ( i fixed it) . The negative coil trigger waveform will also be checked on the first opportunity.
Difference looks reasonable now. Inner exhaust headers are interconnected a bit down the line and they're tucked in so it's understandable they are a bit warmer.
Maybe for jomor147 it might. On my bike CO does nothing to help with vibes or temp diff, and fuel flow was pretty much excluded by swapping injectors around, replacing them and bridging 1&4 from 2&3 connectors.
Thank you for this. My CO settings are set to 0. I do not know what the factory settings were as I bought the bike on 2010 with 11.000Km on the clock (currently 98.800), I am not the first owner and some mechanic must have reset them to zero. Should i try increasing CO for cylinders 2 and 3? Or reduce 1 and 4? In other words how can i check (since - as far as i know - there is no access to long term fuel trims ) if the mixture is lean or rich? Spark plug color did now show something dramatic. I should do the throttle body sync first I suppose, correct?
