dolau
So...... the apparent problem with the radiator fan that stopped the bike from starting has a completely different problem which will virtually scrap the bike. (Still have the problem with the radiator fan I guess)
The mechanic has found the problem- there is corrosion in the plug connecting to the ECU and two pins on the ECU have corroded away and are shorting out the other pins. This is a three year old bike that has done 8000 miles- not a winter hack!
Mechanic says I need a new CPU and possible plug but worse that that I need a new ignition barrel and new set of keys coded to the ECU and the whole bike coded to the ECU as this is the brain of the bike- Estimated cost approaching £2000 :spank:
I dont have £2000 to spenjd on the bike and so would be grateful if anyone on here knows which years ECU's are compatible with my 2009 FZ6S2? I dont know if earlier versions or later vesions would be suitable and hopefully I can find one on EBAY as a set from a scrap donor bike.
The alternative seems to be scrapping my pride and joy and selling it off in bits (other than the ECU) and hope to make enough money to buy another bike
In the meantime- check under the tank to the rear near the shock absorber and see if any water has been getting in- not sure what to recommend then- unplug it and hope nothing breaks so you can vaseline the pins or leave it alone:stupidpc:
