grbl
I have a perfectly good 2004 FZ6 that I'd like to mess with, specifically adjusting the maps for a crackle and pop tune. Is that actually possible? Obviously this is the sort of thing that can easily turn an ECU into a brick, but I'm okay with the risk if there's a known way to do it. I'm especially interested in DIYing it if possible, because that seems neat.
I found tools to pull and adjust maps from another similar-era Yamaha (TDM900, mr_hollywood) but I found the pinout doesn't match the FZ6. The TDM900's ECU pinout shows the flashing-related pins as empty on the harness, whereas the FZ6 harness has fewer pins and no empties. Not too promising.
On the other hand, companies advertise mail-in ECU flashing including for the S1, so I consult your wisdom.
